died while driving, and now she wont start!!!
Old Nov 12, 2013 | 11:54 AM
ajStyles2015's Avatar
Car: 1989 & 1990 RS V8 TBI
Engine: 305 5.0 L
yesterday I was driving at a speed of 50 maybe 55 and I down shifted to 3rd gear for a little power boost, then when I got my RPMs up I shifted to 4th then 5th a few seconds after going to fifth the engine died (radio and everything electronic still on) I pulled over and the starter would turn and turn and turn but there was never any spark.
tonight I'm planning on changing my spark plug cables, ignition coil and distributor.
has anyone had this or a similar experience?? and could maybe point me in the right direction to save me time and money....?
thank you for reading this post it is much appreciated!!!
Old Nov 12, 2013 | 09:57 PM
JunJun's Avatar
Car: 92 camaro convertible z28
Transmission: Swapped from 700R4 to T5
Axle/Gears: Stock Posi. Ratio is not known
Re: died while driving, and now she wont start!!!
Is the fuel pump working?
Old Nov 12, 2013 | 10:16 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
My '91 V6 MPFI died at at full throttle due on the highway to a leaking fuel pressure regulator and a couple of bad injectors. Check for fuel pressure. If you've got pressure check for spark or the ignition control module. Good luck.
Old Nov 12, 2013 | 10:32 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Test before wasting time and throwing parts and $$$ at it
read
http://easyautodiagnostics.com/gm_ic...n_module_1.php
Andrew6.688
Dec 13, 2015 10:59 AM
Wade787b
Sep 29, 2015 01:15 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
