Windshield Washer pump stays on with wipers
Old Nov 28, 2013 | 02:09 PM
The Eager Teen's Avatar
Car: 1985 Trans Am
Engine: 1990 Corvette L98 w/ ported 081s
Transmission: Stock Non-WC T5
Axle/Gears: 9 bolt w/ discs
Hey guys,
As the title says, I installed a Wiper motor assembly from an 83 Camaro into my 85 Trans Am. Everything plugs in fine, but, when I turn on the wipers the washer pump turns on too and stays on as long as the wipers are moving.
As soon as I turn the wipers off the washer shuts off too.
Any idea whats going on or how I can fix this? Is there a difference internally between an 83 and an 85 wiper motor?
Old Nov 28, 2013 | 02:44 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: Windshield Washer pump stays on with wipers
Im pretty sure the wiper motors are completely different between the years. Is this a recent situation or has been for awhile. I say replace the entire thing unless you can take it apart and clean the contacts as sometimes corrosion can cause the board to do odd things
Old Nov 28, 2013 | 03:41 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Originally Posted by The Eager Teen
Hey guys,
its not the wiper motor that youre having trouble with .its the motor cover/logic module that is specific to the car.when you play mix-n-match .this is often the result.try and find a motor cover for your specific car.be advised no body makes a replacement. so, happy hunting
Old Nov 28, 2013 | 08:37 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Search for another replacment unit,... 84-87 Camaro, IROC, Z28 ( NOT Berlinetta ! ) or Firebird, Trans AM, GTA unit will be a direct fit.
Old Nov 28, 2013 | 10:16 PM
Car: 1985 Trans Am
Sigh.
Thanks a bunch guys
Looks like it's back out to pickapart again.
Old Dec 2, 2013 | 04:45 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Rain Pain
Sigh………. Looks like it's back out to pickapart
If you can’t find a cover/circuit board you can install this circuit.
For R1 start with 4700 ohms, and C1 5μF.
That should render about 5 seconds of wash time, and only when you press the Wash Switch.
For more time increase the values of C1 and or R1.
For less time decrease the values of C1 and or R1.
The above will return factory performance.
Happy Racing!
I Didn’t Wreck, The Track Moved
Old Jan 13, 2014 | 12:37 PM
Car: 1985 Trans Am
Re: Rain Pain
Whoops, I never updated.
It turns out I had an extra motor in my garage. Put it on and works fine now.
Thanks for that schematic though!
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
eddie jr
Aug 25, 2015 06:52 PM
slade5612
Aug 11, 2015 07:19 PM
Kaweh
Aug 9, 2015 02:54 PM
