140 MPH speedometer swap question
Old Dec 2, 2013 | 07:34 AM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
I have a general question / observation about the Firebird with electronic speedometers:
Do the 140 speedos use a different pulse signal than the 120? I ask because if it does then you will also need the VSS buffer box for the 140 speedometer, or is it basicly the same gage with a higher top speed?
In my case I have a dakota digital VSS box so I can adjust the pulse signal for any electronic speedometer but if I need to change it from the current setting this means a trip to the chassis dyno to recalibrate the speedometer
I am doing this swap to also have the 8000 rpm tach. I assume the tach nothing special needs to be done.
Old Dec 4, 2013 | 08:15 AM
FRMULA88's Avatar
Car: 1988 Formula
Re: 140 MPH speedometer swap question
I did not think this was too difficult of a question.
Old Dec 4, 2013 | 07:03 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
It's not,..... People swap clusters all the time.
Old Dec 5, 2013 | 08:11 AM
FRMULA88's Avatar
Car: 1988 Formula
So it's simply a remove and replace swap? we shall see.
Old Dec 5, 2013 | 08:23 AM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
Yes the 120 to 140 is as simple as swapping the cluster. Swapping the mechanical 85 mph to a 120 or 140 is obviously more involved.
Old Dec 5, 2013 | 01:53 PM
FRMULA88's Avatar
Car: 1988 Formula
I thought so but wanted to be sure before a take it apart and realize I need another part to finish the swap.
Thanks,
Frozer!!!
Jan 19, 2024 04:55 PM
InfinityShade
Aug 22, 2015 08:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
ChevyZ71
Aug 13, 2015 07:30 AM
