Power locks i thought i never had
Old Dec 10, 2013 | 08:35 AM
topj's Avatar
Car: 88 Camaro IROCZ Convertible
Engine: 305 tbi
Transmission: auto
Iv only had my car for couple months now and i took off the door panel to switch my window motor and noticed the switch and the actuator ..is there anyway i can test them? How can i jump the switch? I tried connecting the middle contact and the left and right contacts on the switch with a 12awg wire but no bueno...any suggestions? Thx
Attached Thumbnails Power locks i thought i never had-image-2896743460.jpg   Power locks i thought i never had-image-559902419.jpg
Old Dec 10, 2013 | 09:40 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Power locks i thought i never had
The 2 pins on the soleniod itself are famous for getting cruddy and not allowing a good contact with the plug. ( & it's not easy accessing those 2 pins with the soleniod installed..... ) The plug also gets cruddy too, but usually not as bad as the plugs. The only way that you will know if it's any good or not is to be sure that those 2 terminals are clean and making good contact with the plug. Once the terminals are clean apply 12 volts and ground directly to the terminals.
Old Dec 10, 2013 | 05:17 PM
topj's Avatar
Engine: 305 tbi
Transmission: auto
Alright thx ill check that out tonight ! Guess ill run a wire from the battery to the solinoid
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
stalkier
Aug 21, 2015 01:54 AM
