Wiper help PLEASE?1988 Firebird V8 5.0
Old Dec 22, 2013 | 05:52 AM
shaubloom's Avatar
Car: 1988 Pontiac Formula Firebird V8 5.
I know there are hundreds of wiper threads on here, however, I havent seen one with my specific problem.
The wipers only work when I hold the spray wash. Otherwise they dont run on any settings. I would assume the motor is good since the wipers move with the wash held on. I have been reading there is no relay for this model. Would the motor have an internal relay? The fuse has been checked and changed.
As anyone heard of this, or have any ideas what may be going on?
Old Dec 22, 2013 | 08:57 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Wiper help PLEASE?1988 Firebird V8 5.0
It could be the wiper switch itself. You will need to do a little trouble shooting to fined out. When the wiper switch is on do you have power to the connection at the wiper motor?
Old Jan 21, 2014 | 06:26 PM
shaubloom's Avatar
How do I check for power at the wiper motor?
Old Jan 29, 2014 | 04:53 PM
NINĊ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Rain Pain
With the wiper unit unplugged, key in the ACCY position, and the wiper switch in the HI position, use a voltmeter or test light (the type for testing for voltage, not a continuity tester) to probe the pink, dark green, gray, and purple wires.
Which wires do you have power on?
Happy Racing!
I Don’t Mind Wreckin’ On The Track, No Paperwork To Fill Out
sammy52401
Nov 11, 2015 07:20 PM
steimel94
Sep 23, 2015 12:48 AM
89bird2.8
Sep 22, 2015 05:28 PM
steimel94
Sep 20, 2015 12:46 PM
