HEI identification
Old Jan 5, 2014 | 11:09 AM
cscotto's Avatar
HEI identification
Hi,
I am restoring a 1984 Z28 HO with my son. The stock carb and intake manifold have been replaced with a Holley 600 cfm (80457-2) and a Wieand aluminum manifold. The ECM has been disconnected, so I know the distributor needs to either be mechanical or vacuum advance type. The distributor in the car is a GM HEI, and it has a vacuum advance. I can only find one set of wires coming off the distributor that connect to the coil. It does not appear to have a connector for the ECM. However, I read that some early HEI distributors were equipped with vacuum advance but they were still ECM. I am trying to verify that I have a non ECM HEI distributor. The reason I ask is the engine has an idling problem. I know there are no vacuum leaks, I have taken care of those. The engine needs to idle fairly high or it stalls. It also cycles in that the rpms go up then down then steady, rinse repeat. I read that would be a symptom of using an ECM HEI distributor that is why I want to make sure about the distributor. I do not know how hot the cam is, so for all I know that is how the engine is supposed to idle. Thanks in advance.
Old Jan 5, 2014 | 04:14 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: HEI identification
If it has vac advance it is a non CC dist
All CC dist have a 4 wire plug from the base for the ECM connection as well as the wiring to the cap you have
Old Jan 5, 2014 | 07:23 PM
cscotto's Avatar
Thanks!
sreZ28
Oct 22, 2015 08:21 AM
skinny z
Oct 5, 2015 06:23 PM
Justins86bird
Sep 27, 2015 09:43 AM
Damon
Sep 26, 2015 04:29 PM
RedLeader289
Sep 23, 2015 06:50 AM
