Where can I find the voltage specifications for my instrument gauges on a third gen
Car: 1987 Camaro sport
Engine: V6 2.8L
Axle/Gears: Stock
I suspect that my temperature gauge is inaccurate. I want to remove it and calibrate it out of system using a meter calibrator I have at work. But I need to know the voltage/current range of the gauge in order to properly calibrate/adjust it. I own a 1987 Camaro.
Car: 1991 camaro rs
Axle/Gears: stock
Re: Where can I find the voltage specifications for my instrument gauges on a third g
it should be a 10-14.4 volt range. it works on resistance off the negative of the gauge. it probably works on a milliamp range so don't put too much on it. what kind of meter calibrator are you using?
Engine: V6 2.8L
Axle/Gears: Stock
I work as a calibration tech in the Marine corps. We have millions of dollars worth of precision measurement test equipment. I was planning on using a 5700ANV meter calibrator. But for the temperature gauge I was gonna try to use a 2000MEJ temperature calibrator
Engine: V6 2.8L
Axle/Gears: Stock
What do you mean it work on resistance off the negative of the gauge?
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
db057
Aug 11, 2015 10:11 PM
