Cruise control switches on manual trans pedals?
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Hey guys, I have a 91 Trans Am which is undergoing a transmission swap (700r4 to t5) and I was just wondering how to hook up the cruise control switches to the new clutch/brake pedals. On the automatic brake pedal, there was an electric/vacuum switch (had two electric leads coming out along with a vacuum hose), while on the manual pedals, there's a vacuum switch on the brake and electronic switch on the clutch. Is it just plug and play? I can get pictures later today of that'll clear things up.
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
Re: Cruise control switches on manual trans pedals?
Ever get an answer to this? Im in the same boat...
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Auto Pilot
Keep the brake pedal switched as they are.
Just add an electric switch in parallel to the one on the brake pedal to the clutch pedal.
Happy Racing!
If My Engine Has An Illegal Part, And The Inspector Doesn’t Hear It, Does It Make A Sound?
Happy Racing!
Car: 1992 RS Heritage Edition
Engine: LS6 Mut
Axle/Gears: Stock
Sorry to hijack but does anyone know what color and where the wires are for the cruise switch on the blinker switch? I have a 92 rs that I did an ls6 swap on. I need to splice in the wires for cruise on, set/accel, and resume.
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
just finished repairing the wiring on my 91 and 92 the clutch switch get tied into the brake switch its job is to stop the cruise when you push the clutch
Easiest way to do it is, just get the pedals out of a stick car with cruise.
My 83 is such a car. 5-spd w cruise. They're by no means rare.
Beats the crap out of "alternate ethnic" engineering something ... risky. I have a deeply instilled fear of the reliability of anything that can hold the gas pedal down besides my own foot.
Engine: LB9
sofa, I think it's easier for me to play with some wiring at this point than replace the entire pedal assembly lmao. But I took the car for a drive and the cruise control works fine. The brake pedal disengages it but the clutch doesn't; should be an easy fix. I'm gonna try to take a look this weekend because it's been a couple months since I rigged up the pedals and I don't remember what I did LOL
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Here's a pic of the Cruise system system from an 86 :
I'm pretty sure the wiring is spliced in parrellel under the factory black tape right before the split. The 90-91 systems might be a little different - but should be 'similar'.
Engine: LS6 Mut
Axle/Gears: Stock
See...I can't find the little black plug with the 4 wires on it..??? Where TF is it!!!!???? Lol
The connectors changed from year to year. I could be wrong, but I'm pretty sure this is the 90-92 'dash-side' Cruise set-up from an automatic.
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
