hard wiring headlight module and headlights.
Old Jan 30, 2014 | 08:23 PM
shwinny's Avatar
I have an 87 GTA with a recently installed 383 stroker. I need to wire a switch or button in the car to power the lights and light motors. From the module whats the ground wire and whats 12v ignition. Has anyone done this. Any help would be greatly appreciated. it would be nice to have a switch that opens the headlights and another that turns the lights on. Please Please Please, im not new to this forum im just new to wiring.
Old Feb 5, 2014 | 09:16 PM
shwinny's Avatar
Re: hard wiring headlight module and headlights.
Can anyone help me out. Or point me in the right direction. I need headlights/wipers/ hell I will manually open the headlights if I can just some direction on why my headlights/trunk motor/headlight motors/and door locks not working. I will hard wire them all if I have to. I just need to know if I'm missing somthing stupid before I start hard wiring. Please I'm begging.
Old Feb 6, 2014 | 09:59 AM
RyanJB's Avatar
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
Did you check your fuses? What have you checked so far?
Old Feb 6, 2014 | 04:18 PM
shwinny's Avatar
I've checked all fuses relays and most all grounds. I just need some pointers on figuring out this issue.
Old Feb 7, 2014 | 05:25 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Attached Thumbnails hard wiring headlight module and headlights.-doormodulediag.gif
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
db057
Aug 22, 2015 08:17 PM
stalkier
Aug 13, 2015 12:59 PM
