starter help?
Old Nov 30, 2013 | 04:39 PM
scarbucket's Avatar
Car: 1987 Firebird Formula
Engine: 355
Transmission: Borg Warner 5 spd
Axle/Gears: 3:43
starter help?
ok I am looking for the starter relay to engage the starter I have the power in or b+ wire need to find the ignition wire that opens the circut or the s+ i think? cannot find the second wire. Any help is greatly appreciated guys sorry for the dumb question.
Old Nov 30, 2013 | 07:51 PM
Barlow8869's Avatar
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
Re: starter help?
if it has a vats, i think there is a relay in the drivers side kick panel ... you did not say if it was a stick or auto though, or what year it was, or if it has a vats or not ... more info could be helpful ... also if you would say what the car is doing or not doing may help as well
Old Nov 30, 2013 | 08:15 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: starter help?
In his profile
Car: 1991 firebird
Engine: 3.1 swapped to a 350 small block
Axle/Gears: solid rear axle
See
https://www.thirdgen.org/vats_passkey_system
Old Dec 1, 2013 | 03:24 AM
scarbucket's Avatar
Engine: 355
Axle/Gears: 3:43
Sorry bout that its a 91 auto originally a 3.1 now a 350 with ecm delete trying to find the power wire from relay to the starter so I can hook up the starter
Old Dec 1, 2013 | 06:02 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: starter help?
Where are you looking ?
There should be a purple wire in the engine bay by where your old V6 starter was
that operates the starter
Old Dec 1, 2013 | 10:59 AM
scarbucket's Avatar
Engine: 355
Axle/Gears: 3:43
Ok I was looking in the bay trying to find it with a test light lol hit the key and probe wires since I got no ecm I and gotta worry about back probing one but anyhoo thanks what where they saying about crossing wires to make it work?
Old Dec 1, 2013 | 04:43 PM
scarbucket's Avatar
Engine: 355
Axle/Gears: 3:43
Re: starter help?
so does the solenoid wire act as the ground completing the circut then I got the purple wire but no power to it or am i missing the feed for the relay somewhere?
Old Dec 1, 2013 | 07:35 PM
Barlow8869's Avatar
Re: starter help?
did you check it for power with the key in the start position? (sorry to ask such a simple question, but sometimes people overlook the simple stuff)
and no, it gets it ground from being bolted to the block, so make sure your ground wire to the block is in a good clean place
also, if you have to have the car right now, you can always mount a starter switch under the dash and take power straight from the B+ to the switch, then out to the starter where the purple wire goes
Old Dec 1, 2013 | 07:39 PM
scarbucket's Avatar
Engine: 355
Axle/Gears: 3:43
Yea I did I had a guy hit the key while I was probing with a test light and got nothing I am trying to find the actuall relay to check it but it all worked before the swap thats why im confused
Old Dec 1, 2013 | 07:47 PM
Barlow8869's Avatar
Re: starter help?
did you check all your grounds ... do all the lights work right? ... do you maybe have both turn signal lights in the dash come on when you turn on your headlights?
Old Dec 1, 2013 | 07:51 PM
Barlow8869's Avatar
Re: starter help?
also, there is a "relay" in the drivers side kick panel (just to the left of the pedals under that panel) if you had a vats system, you will have to bypass that to get power to the purple wire ... it works a lot like the safety switch on a clutch
Old Dec 1, 2013 | 08:08 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: starter help?
Bottom of page
Does the purple you found have a metal ring terminal on it ?
Old Dec 1, 2013 | 08:11 PM
Barlow8869's Avatar
Re: starter help?
Originally Posted by vetteoz
No need , the wire you are looking for is PURPLE
The only other purple wire in the engine bay should be the O2 sensor wire which has
a black plastic connector on it , the starter wire has a metal ring terminal
he had found the purple wire, but now it has no power to it with key in the start position
i think he may need to bypass the starter disable for the vats still though
Old Dec 1, 2013 | 09:54 PM
scarbucket's Avatar
Engine: 355
Axle/Gears: 3:43
Yes the two grounds are good I get both indicator lights comeon for the turns when headlights are on
Old Dec 1, 2013 | 10:01 PM
Barlow8869's Avatar
Re: starter help?
do they come on when the turn signals are off, but the lights are on? ... and do you have a vats in your car?
does your key look like this one? http://www.michaelhyde.com/assets/im.../S595519-2.jpg
Old Dec 1, 2013 | 10:03 PM
scarbucket's Avatar
Engine: 355
Axle/Gears: 3:43
Yea they Do what is vats?
Old Dec 1, 2013 | 10:04 PM
scarbucket's Avatar
Engine: 355
Axle/Gears: 3:43
Yea I got a chipped key
Old Dec 1, 2013 | 10:17 PM
Barlow8869's Avatar
Re: starter help?
ok, vats is the Vehicle Anti Theft System ... and it will not let the starter engage without the proper signal ... easy way to test that is ... Remove Driver side kick pane and its recessed into the body there. Lil green wire, ground that, no vats ignition passkey required ... and if your turn signal lights light up with the headlights on, but the signals turned off, it should have a bad ground still ... make sure the ground strap from the back of the motor is bolted to the body, and make sure that the ground cable from the B-is tight to the motor, and in a place that is not shielded with rubber (like dont have it hooked to a motor mount)
Old Dec 1, 2013 | 10:20 PM
scarbucket's Avatar
Engine: 355
Axle/Gears: 3:43
Ok thanks ill play with it some more and let ya know if that works
Old Dec 2, 2013 | 05:06 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: starter help?
what is vats?
All explained in the link I posted for you to read above as well as a pic of where the relay you seek is located
Old Feb 8, 2014 | 02:42 AM
scarbucket's Avatar
Engine: 355
Axle/Gears: 3:43
Ok I got the green and black grounded and I still cant figure this out I got vats disabled because the security light goes out but I dont get power to the 10g ppl wire when I hit the key? Could I not have something right still I think its a power wire to the interior bc I got all grounds good and I only got half my int stuff no dash lights dome lights etc ill look tomorrow lol sorry I just finally got time to get back to it gma was sick and finally passed so that took all my time up.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
