fog lights with LED bulb to DRL the easy way
Old Feb 22, 2014 | 11:20 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Thought I may share this, since I could not find any related information anywhere when I was looking.
Here is a very simple way to allow the fog lights to work independently from the park and/or driving lights.
This allows the fog lights to be used as manually controlled DRL.
This is on a 91 GTA, but the idea of using an "ignition ON, hot wire" to power the O.E. fog light switch should work on many other cars too.
On the right is the O.E. fog light switch, the braun (park and/or driving ON, positive wire)wire needs to be cut and spliced to a "ignition ON, hot wire".
Here in this case it is spliced to the defroster switch pink/black positive wire that stays hot with ignition/ON.
The black isolation tape is to isolate the wire that is no longer used.
Attached Thumbnails fog lights with LED bulb to DRL the easy way-fog-light-drl-switch.jpeg   fog lights with LED bulb to DRL the easy way-oe-fog-lights-drl.png
Old Feb 23, 2014 | 10:44 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Re: fog lights with LED bulb to DRL the easy way
Awesome
Old Feb 23, 2014 | 04:18 PM
thomas1976's Avatar
Car: 91 Trans am
Are you saying that because you have no fog lights?
Old Feb 23, 2014 | 09:29 PM
KITT1983's Avatar
you mean these foglights.
Old Feb 24, 2014 | 06:56 AM
thomas1976's Avatar
Car: 91 Trans am
nice!
Old Feb 24, 2014 | 07:58 AM
KITT1983's Avatar
nice!
Thats a good Photoshop of I want
Old Apr 25, 2014 | 09:56 PM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
when wired this way, do the fog lights turn off with the high beams? I wonder if a jumper could be used to connect the brown wire to the pink wire with the black stripe without isolating the brown wire
Old Apr 26, 2014 | 04:44 AM
thomas1976's Avatar
Car: 91 Trans am
I have not tried it, but I'm sure the fogs will stay on if you do not turn them off.
Brown connected to pink, will probably cause short circuit.
GTAman
Mar 15, 2019 11:40 AM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
tealman92
Exterior Parts for Sale
Aug 27, 2015 11:21 AM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
