Couple connections
Old Feb 22, 2014 | 09:49 PM
JacobIroc's Avatar
Car: 92 RS 25th Anniversary
Engine: 305 TBI -> 305 TPI
Transmission: T5/T56
Axle/Gears: 3.08 - 3.73+ soon
Couple connections
Alright. So i'm about done with my 92 Camaro TBI->TPI. This is a 86 305 TPI, so I had to splice to much bullshit >.< anyways. I don't know what these connectors are. or what this plug is. The plug is with all the starter wiring and the connectors are under the distributor.
Old Feb 22, 2014 | 10:09 PM
Ransford2987's Avatar
Car: 1990 IROC-Z/1980 Firebird
Engine: 5.7 TPI
Re: Couple connections
That bottom one from the top pic looks like an oil pressure sending unit (the larger one). Both look to be coming off the same piping tee, so I imagine the one with two connections is also for oil, though it looks like a temp switch. The bottom pic is too close. Try getting the color of it and where in the wiring loom it comes from.
Are the two in the top pic connected to the trans or the engine block?
Old Feb 22, 2014 | 11:00 PM
JacobIroc's Avatar
Thats helpful. I was thinking oil aswell. They are coming out of the engine block.
I got another one for you. It's right next to the CTS
Old Feb 22, 2014 | 11:16 PM
Engine: 5.7 TPI
I don't have the CSI so I had to look this up, but it's the cold start injector switch (thermo/time delay?). https://www.thirdgen.org/forums/tpi/...old-start.html
anyway, there's more info on it in the link just in case.
Old Feb 22, 2014 | 11:28 PM
JacobIroc's Avatar
I don't have the CAI so I had to look this up, but it's the cold start injector switch (thermo/time delay?). https://www.thirdgen.org/forums/tpi/...old-start.html
Thank you
Linson
Sep 21, 2015 01:08 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Ranbo108
Sep 9, 2015 12:20 PM
