tune port cold start injector quesion
Old Dec 30, 2012 | 04:42 PM
madigidy's Avatar
Car: 89 iroc z restoring
Engine: from 5.0 to 5.7
Transmission: from Auto to 5spd
Hello Everyone,
i just had a swap done on my 1989 ( used to be 5.0 auto iroc z). i installed the complete drivetrain, 5.7 engine/w harness and computer and 5sp trans/w accessories, from a 1987 iroc.z. at his point the will only start after i spray carb cleaned into the intake. i just read that in 1989 chevy deleated the cold start injector. my question is if the engine is calling for the injector to prime, what would be the best approach. is there some sort of aftermarket device for this issue. can a wire be ran in some sort of way to the injector. im lost please help... thanks
Old Dec 30, 2012 | 06:12 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: tune port cold start injector quesion
Was the engine starting cold correctly before you installed it?
Does it start without the spray when the engine is warm ?
If not you have other problems
On a '87 the CSI is purely electrical; not connected with the computer like on '89+ cars
A switch supplies power to the CS injector only while the engine is cranking over ( and only when the engine is cold )
Check the cold start switch at front of intake to see if it has 12V when cranking and is outputting 12V to the cold start injector
You may not have the power wire connected to the starter terminal
CSI Switch is the brass hex head unit to left of CTS circled in pic
Old Dec 31, 2012 | 08:41 AM
madigidy's Avatar
Hey Vetteoz
The 5.7 engine ran perfect before I pulled it out of the donor car.
Now as far as 5.0 engine it ran at first, then I had to replace the fuel pump
Then it ran but rough.
You mentioned the switch supply power to the cs. Is that power coming from the ignition switch on the column, and is sent to the csi. Because the column was changed. But the only thing I did not change was the harness under the dash and thru out the car.
Old Dec 31, 2012 | 09:11 AM
88transam 88's Avatar
Car: 1988 TransAm
Engine: sbc 9:8:1 cr 40os slugs rhs heads
Transmission: th400 3800stall b&mkit manual vb
Axle/Gears: stock
Double check your fuel pressure just to be safe
Old Dec 31, 2012 | 11:44 AM
madigidy's Avatar
i just spoke to the owner of the shop and he said the fuel pressure is between 38-45. he is going to check the power to the csi when he gets to the shop.
Old Dec 31, 2012 | 01:36 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
45psi is with the engine running and vacuum hose on the fuel pressure regulator. 38psi will be with vacuum disconnected from the fpr.
http://www.amazon.com/Bosch-02801302.../dp/B001COAWQK
if this turns out to be a cold start issue you might be better doing a custom tune to the 89 $6e starting with a corvette .bin and changing the spark advance and lv8 tables sine there was never a production f-body tpi L98 manual trans.
Old Jan 1, 2013 | 01:19 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Originally Posted by tunedperformanc
45 psi is with the engine running and vacuum hose on the fuel pressure regulator. 38 psi will be with vacuum disconnected from the fpr.
So my car is back a$$wards as my fuel pressure is 32 psi at idle and increases as vacuum decreases. maybe I should connect the FPR to ported vacuum instead of manifold vacuum? I don't think so, but my manual and I could be wrong.
Old Jan 1, 2013 | 06:39 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Pressure is typically 45 psi with vac line disconnected.
Should be around 39 -40@ idle with vac line connected and pressure should rise as vac drops.
High vac lifts the diaphragm connected to the valve in the reg up reducing the pressure ;
when vac drops the diaphragm is lowered and pressure rises
http://www.howstuffinmycarworks.com/...regulator.html
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
Jake_92RS
Aug 11, 2015 10:39 AM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
