car won't start.
Car: 1992 Camaro
Engine: Ls1
Axle/Gears: Currie 9" 4.30
car won't start.
I had disconnected the battery to install an a/c delete box. Install everything then reconnect the battery and the dash lights and the exterior lights start flashing and the car will not start. I looked at all the grounds and had the battery tested. I am lost on what to try next. The car has an ls1 t56 swap if that will help any.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Car Is Not Cranky . . . . SO I AM !!!!!!
Use voltmeter or test light (the type for testing for voltage, not a continuity tester) to probe the wire going to the solenoid power input.
Make the wire long enuff to bring into the cockpit.
Now, when you try to crank, is there power?
Happy Racing!
If Your Communications Antenna Is Not Shaking At Idle, Your Cam Is Too Mild
Happy Racing!
theshackle
Mar 5, 2017 06:37 PM
