Those with Contour Window switches
Old Feb 25, 2014 | 04:50 AM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
I picked up a set of Contour window switches from the JY for my 4th Gen console swap. Iv ohmed up and down and they work. However, I can't get the illumination to ohm out (or work).
According to schematics I found, the illumination circuit is purple to thin black wire. Doesn't ohm. Mine has a thin orange/blue wire coming off of them that I can't find in any diagrams, but it doesnt ohm out either for illumination. Are BOTH switches illumination bad or am I missing something?
Any help is greatly appreciated.
Old Mar 3, 2014 | 04:58 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
LED SLED
They might be LEDs therefore won’t “ohm” (show expected resistance readings).
Re-probe the wires, reversing the leads on each suspected lamp wire pair.
If the reading is different upon reversal you have found LEDs.
Happy Racing!
If Your Communications Antenna Is Not Shaking At Idle, Your Cam Is Too Mild
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
383cam
Sep 9, 2015 06:01 AM
SG91camaro
Sep 5, 2015 10:27 PM
luvofjah
Sep 3, 2015 07:08 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
