Help wiring speedo
Car: 1987 Camaro IROC-Z Z28
Engine: Custom Vortec 350
Axle/Gears: 3.73, Auburn Pro Series diff
Help wiring speedo
I have a 1987 Camaro 305 TPI that I did a carb swap on. We removed the ECM and ECM wiring.
I need help on how to wire up my Speedo.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Help wiring speedo
Your 87 Camaro speedo is controlled by a cable, not the ECM.
If the speedo isn't working after an engine swap,..... to look under the car to be sure the speedo cable is properly connected at the tranny tailshaft.
If it IS connected,..... find the cable under the dash housing and be sure it's pulled into the cluster properly.
If both ends of the cable are connected correctly and the Speedometer is still not working right than the Speedometer itself, Speedo cable, or Speedo Gears ( inside tranny ) are causing the problem.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
beachrodder
Aug 7, 2015 04:27 PM
