No gauge lights or some light
Old Mar 2, 2014 | 09:12 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
I've searched through old threads but none are really similar. The gauge lights and dome light don't work. The radio, check engine, brake light, courtesy lights, radio, headlights, tailights, blinkers, power mirrors, horn, parking lights, and power locks all work. All the fuses are good, is it still possible I need a remote dimmer switch? Where are the grounds I should check? PO installed a kenwood radio and there is a wire for it running to the fuse box, what should I try? Car is an 86 trans am 305 tpi
Old Mar 2, 2014 | 10:15 PM
TylerSteez's Avatar
Engine: 383 stroker
Re: No gauge lights or some light
Here's pics of the wiring if anyone can see anything odd, the PO severely hacked it up.
Old Mar 2, 2014 | 10:19 PM
TylerSteez's Avatar
Engine: 383 stroker
Is the white piece with the metal rod going into it the dimmer switch?
Old Mar 3, 2014 | 06:29 AM
Yes that's the dimmer switch; changes the headlights from low beam to high beam. Not related to the dash lights.
I'd suggest, try to remove all that .... stuff ... the PO put in there; put it back stock; and go from there. Pretty hard to troubleshoot a mess like that.
Old Mar 3, 2014 | 06:32 AM
TylerSteez's Avatar
Engine: 383 stroker
I've been reading that there's another dimmer switch that controls dimming the interior lights that could be bad. I'd love to put it back to original but I don't have the knowledge to do so, just a 17 year old in highschool
Old Mar 3, 2014 | 07:18 PM
TylerSteez's Avatar
Engine: 383 stroker
Bump for any ideas?
Old Mar 3, 2014 | 07:19 PM
TylerSteez's Avatar
Engine: 383 stroker
Bump for any suggestions?
Old Mar 10, 2014 | 05:03 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Diminishing Returns
There’s no dimmer for the interior lights but there is one for the dash.
You mentioned Remote Dimmer.
If you have that in your car it could be the dimmer wheel but first do some measurements.
Using a voltmeter or test light
(the type for testing for voltage, not a continuity tester) probe the dark green wire with the WHITE stripe going to the dimmer wheel.
When you rotate the wheel back and forth — what happens on the meter or test light?
Then probe the
brown wire.
Then probe the probe the plain
dark green wire.
Happy Racing !
My Brakes Don’t Work AT ALL When The Car Is Sliding On It’s Roof
Old Mar 10, 2014 | 06:14 PM
TylerSteez's Avatar
Engine: 383 stroker
Re: Diminishing Returns
Then probe the
brown wire.
dark green wire.
Happy Racing !
I meant to say the dashboard lights, just bought a meter this week, I'll test it on my day off from work, thanks
Ghettobird52
Jul 5, 2024 11:18 PM
dibella989
Sep 1, 2015 04:12 PM
justin57
Aug 20, 2015 07:05 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
