Suggestions on Switches
Car: 1988 Chevrolet Camaro IROC-Z
Engine: 408 LSx
Transmission: T56 Magnum
Axle/Gears: 3.73 10-Bolt Detroit TrueTrac
As part of my motor swap and going from TPI to carb I'm gonna be placing a switch panel above the radio in my IROC.
I'm looking to have the fuel pump, fans, lights, a nitrous arming switch, etc on the panel.
I want to run a switch for each fan, but I want to run On/On (Auto, the second on will leave the fans at the mercy of the relays, while the first will be on while the ignition is on) for the cooling fans.
I'm looking for a quality set of switches. Square/rectangle rocker switches, in black, with red LEDs.
I'll need On-Offs, On-Ons, On-On-Offs (or On-Off-Ons), and a momentary On-Off.
A couple of push-button momentaries (one for nitrous activation, another for push-button start, maybe) would also be good.
Any suggestions would be awesome. I was looking at some Painless switches on Summit, but if anyone has anything better I'll take a look.
Engine: 408 LSx
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Suggestions on Switches
As was said Radio Shack has a nice selection of rocker switches and more.
Here’s there site. If you can’t find it here they probably don't make it.
= http://www.radioshack.com/family/ind...rodsPerPage=60
I read your post and think you said all switches will be on relays.
Right ?
Right ?
Engine: 408 LSx
Heres there site. If you cant find it here they probably don't make it.
Right ?
Right ?
And no, the only switches that will be run to relays will be the switches for the fans, and that's so I can either turn them on when I want to, or let the temperature switches do it.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Switching Subjects
You probably will find all you need at SpeedwayMotors.com
They have all the Oval Track and Drag switches you’ll probably ever need.
Happy Racing !
My Brakes Don’t Work AT ALL When The Car Is Sliding On It’s Roof
Happy Racing !
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
