Hazard Mounting tab broken
Old Mar 19, 2014 | 11:34 PM
transaero's Avatar
Car: 1987 Trans Am GTA
Engine: Warmed over 350 TPI
Transmission: 700r4 soon to be t56
Just when I thought I was finished with the electrical work, something else pops up.
After getting a new hazard switch (the part you push/pull to activate the hazard blinkers), when I tried using the switch, I noticed how loose and wiggly it became. Took it back out, and the tab it mounts to on the inside of the column was broken.
Now my main question is, is this repairable or will I have to take the column apart or replace it? This is really becoming a pain in my you know what, all for turn signals.
Thanks guys, any help is greatly appreciated.
Old Mar 19, 2014 | 11:47 PM
transaero's Avatar
Re: Hazard Mounting tab broken
Also some (crappy) pics, so you can see what I am talking about.
Old Mar 26, 2014 | 01:33 AM
transaero's Avatar
Thanks for the help guys....
Anyways, it was part of the turn signal switch. I found some of the instructions on here on how to disassemble the column and put a new switch in. It also fixed a wire short that I had before.
skeltor
Feb 2, 2016 10:37 AM
snakeshooter
Sep 7, 2015 11:15 AM
FormulasOnly
Sep 6, 2015 10:42 AM
SG91camaro
Sep 5, 2015 10:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
