Need help identifying plug under dash & buzzer
Old Mar 25, 2014 | 06:52 PM
graysmoke's Avatar
Car: 91 Convertible
Engine: Stock 305
On my 91, I was looking for the key/headlight buzzer (which I think is removed) and found this plug near the fuse box. Its not attached, just hanging like there should be a relay or something there. Does someone know what its for? Thanks for your help.
Attached Thumbnails Need help identifying plug under dash & buzzer-wp_20140325_009.jpg
Old Mar 26, 2014 | 01:40 AM
transaero's Avatar
Car: 1987 Trans Am GTA
Engine: Warmed over 350 TPI
Transmission: 700r4 soon to be t56
Re: Need help identifying plug under dash
Not sure what that connector is, I have a '87 car so I might not have it, but I'll check tomorrow.
As for the chime(door/key alarm thingy), it is located on the right side of the steering column, on the courtesy panel. It is a blue rectangular box. There should also be a hazard and horn relay right next to it.
Old Mar 26, 2014 | 07:35 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
That connector is for the fog light relay.
The headlight/key buzzer on my 92 is black. I removed it cause it was shorted internally and never shut up. You can't miss it though, it sticks straight out of the convenience panel and is about the size of a pack of cigarettes.
Old Mar 26, 2014 | 08:59 AM
graysmoke's Avatar
Car: 91 Convertible
Engine: Stock 305
ok, that helps and explains my fog lights were removed at some point.
I found the location of the headlight warning buzzer relay and it was missing. Some people cant deal with the annoyance and yank it out. Got one off ebay. Also found that buzzer OEM GM 1403421 can be replaced with a newer chime relay GM part number 14101255.
update: I have a 96 GMC truck. I looked under at the chime alarm on it and it looks like the same "convenience center" plug ins chime relay/flasher/horn units as on the camaro. I pulled the chime module out of it to test my camaro and headlight/key in/door worked. I could not test the seat belt alarm. The part number on that is GM 15969639 - it has a nice tone. So there are more of these GM units that will work besides the original part.
Old Mar 26, 2014 | 01:49 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
I found the location of the headlight warning buzzer relay and it was missing. Some people cant deal with the annoyance and yank it out. Got one off ebay. Also found that buzzer can be replaced with a newer chime relay GM part number 14101255.
Perfect timing, graysmoke! The T/A I just bought had it's blue chime module in a bag with the owner manual, in the rear compartment. I'm assuming it failed, and he removed, rather than replaced, it. If I can't find an original, I'll check on that newer part #. Thanks for sharing that.
Old Mar 26, 2014 | 04:37 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
That makes a kind of sense. GM used the same parts on a lot of vehicles, and that is one that could easily be a common component. Just wish I had thought of checking that before I got rid of my 94 GMC truck. I probably could have replaced the one in my camaro with it before I scrapped the truck.
FWIW, my 92 has the same foglight relay connection, but didnt come with foglights from the factory.
rocn7roc
Sep 21, 2021 02:16 PM
LittleFranks
Sep 17, 2015 12:22 PM
Linson
Aug 21, 2015 02:12 PM
Street Lethal
Aug 14, 2015 08:25 PM
apie2546
Aug 8, 2015 07:12 AM
