fuse problem
Old Apr 6, 2014 | 03:04 PM
patriots781's Avatar
Car: firebird 91
Engine: 350 5.7 small block
Transmission: turbo transmission
fuse problem
So I checked the fuses and replaced some and say the turn signal won't run on the 20 but it'll work on a 30 fuse that's the same story with a couple of them I put brand new fuse in and it won't work??
Old Apr 8, 2014 | 04:38 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Fusin’ For a Cruisin’
You didn’t say the lower amp fuses blow so we will assume they don’t.
The only reason it wouldn’t work with the 20 is because the prongs were not making contact, or it’s defective right out of the box.
You can verify with a voltmeter or small light bulb.
Happy Racing !
Even Tho I Might Destroy The Car During The Race, At Least It Looks Gorgeous At The Start
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
greenyone
Sep 2, 2015 03:39 PM
