Cap and rotor
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: Cap and rotor
i don't know but i had the same problem.i assumed it was cheaply made parts and replaced them with brand name high performance parts.
Engine: TBI,5.0
Re: Cap and rotor
MSD Cap and rotor kit =
http://www.summitracing.com/parts/msd-8406/overview/
I bought the same one as a replacement.
Maybe MSD has an economy line of products
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: Cap and rotor
Did you put any dielectric grease on the center of the cap and middle of the rotor?
Engine: TBI,5.0
Re: Cap and rotor
No, I did not know you should.
If it will help keep this from happening than I will.
I've never seen a rotor cap or terminals in the cap look this bad.
Is the problem contained within the cap or could the Ignition Control Module and Pick up coil play a roll.
The module is about 6 years old and the pick up is most likely stock.
The main reason I ask is because Ive been looking for the cause of an intermittent stalling problem. It will stall at a light and then I have to tap the throttle when I go to start it again.
tyeo098
Nov 30, 2015 06:27 PM
