1982 transam headlight repair FYI
Old Apr 19, 2014 | 07:32 PM
fteufert's Avatar
Car: 1982 T/A
Engine: 1973 400 Chevy
Transmission: 4 Speed Borg Warner
Axle/Gears: 3:23
I am sure this was discussed a few times, and I found some help by searching, but:
My passenger headlight would not go up when the switch was turned on, but it went down when shutting the lights off. The drivers side worked fine.
I pulled a replacement motor from a 1984 Fiero at a local U-pull it yard, with the relay still attached.
It turned out my original motor was cracked, and the Fiero one fit fine, but had the same issue. The problem was the relay. Once I swapped the Fiero relay in, the light went up and down fine, even when using the original motor.
So, if you need some headlight parts, scavenge parts from a Fiero. I am going to pull the relays out of the other 3 Fiero's that are there just in case.
SRKLEGIN
Sep 30, 2015 07:19 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
indygene
Sep 26, 2015 11:21 AM
