305 tbi injector signal test?
is there a way to test if the ecm is signaling the injectors? I have a 92 r s that has a fuel problem. I was told this car has a bad fuel pump. But after learning what a nightmare the VATS system is I am trying to eliminate the other problems that could cause a no fuel situation. the starter works the ignition works the motor will run if you dribble a little fuel down the intake. if I can eliminate the injector problem that the ecm is signaling the injectors I can concentrate on the fuel pump system.
Axle/Gears: 10 Bolt 2.73 Open
Re: 305 tbi injector signal test?
