intellitronx fuel gauge problems
Old Apr 24, 2014 | 09:01 PM
tmork454's Avatar
Car: '87 Camaro
Sorry for posting this in the carburetor section.
I just used a multi meter on the one red wire coming out of the gas tank (because my car was swapped to a carb 350 by the last owner) and found that it was reading 69 ohms. When i measured the voltage on the pink wire coming from the dash it measured 5 volts. I thought the gas tanks operated on about 3 volts. If thats true how could i lower the current? Im pretty sure the sending pump is working correctly because the fuel level was working until i put that new intellitronix dash in.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
justin57
Aug 20, 2015 07:05 PM
Jk_Under
Aug 17, 2015 03:08 PM
