intellitronx fuel gauge problems
Old Apr 24, 2014 | 09:02 PM
tmork454's Avatar
Car: '87 Camaro
Sorry for posting this in the carburetor section.
I just used a multi meter on the one red wire coming out of the gas tank (because my car was swapped to a carb by the last owner and they cut the pink tan and black wires that went to the old tank) and found that it was reading 69 ohms. When i measured the voltage on the pink wire coming from the dash it measured 5 volts. I thought the gas tanks operated on about 3 volts. If thats true how could i lower the current? Im pretty sure the sending pump is working correctly because the fuel level was working until i put that new intellitronix dash in.
Old Apr 28, 2014 | 04:52 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Color Calamity
The changing of the colors by the PO is giving you headaches.
No part of the “fuel tank” “operates at 3 volts”.
However the voltage from the level sensor will vary from almost zero, then approach battery voltage as the level changes.
Here’s how to check the sender:
Remove the sender wire going to the gage.
Connect an ohmmeter between ground and that wire.
A correct reading will be between zero and 90 ohms.
But zero might be a short so have at least a ¼ gallon in the tank so you get some resistance.
Happy Racing !
If We Don’t Get Cawt We Ain’t Cheatin’
Old Apr 29, 2014 | 12:58 PM
tmork454's Avatar
Car: '87 Camaro
I have tested the sender wire and the sender is working. But when the sender wire is reading like 65 ohms the fuel gauge reads around 90% fuel.
Old Apr 29, 2014 | 05:12 PM
NINÅ's Avatar
Transmission: 765R4
Color Calamity
That isn’t far from perfect, because when the sender is at 90Ω, the gage should be at or above the FULL mark, and when the sender is at 0Ω, the gage should be at or below the EMPTY mark.
We can look into the Intellitronix dash at a future time, but the info I posted will properly operate a stock, and many aftermarket gages.
Happy Racing !
Old May 2, 2014 | 01:56 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: intellitronx fuel gauge problems
Contact the manufacturer of the dash and find out what resistance range their fuel gauge is made to work under. Most are the 0-90 but not all. Also, not a bad idea to also check resistance of the wires at the dash connectors.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
justin57
Aug 20, 2015 07:05 PM
Jk_Under
Aug 17, 2015 03:08 PM
