A Possible Security Trick?
Old Apr 24, 2014 | 11:03 PM
DanzigEx's Avatar
Car: 1986 Z28
Engine: 305 LG4
Transmission: TH700R-4
Hey folks, I'm new to TGO and loving the info and Third Gens on here!
Anyways, I was browsing the Industrial Electrical Section on Amazon, and noticed some Key Operated Switches! I was thinking, what if we mounted one of these switches before the ignition switch? It could be an extremely cheap security feature, just put the switch key in and turn on, then start the car as normal.
Would this be a good idea, or do you folks think it's not to worth trying?
Old Apr 25, 2014 | 12:55 AM
fervernt's Avatar
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
Re: A Possible Security Trick?
personally I prefer a hidden toggle switch. cheaper, and the key is just one more thing to lose(and I lose keys a lot lol). a toggle switch is just as secure if its hidden well enough. and if your car has VATS I think thats more than sufficient anyway.
Old Apr 28, 2014 | 04:53 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Theft-Proofing
Good info from fervernt.
However Danzig, your idea is also good.
If you keep the key on the same ring as the other car keys and lose the keys the point is moot.
There is an almost unlimited amount of ways to keep the pathetic morons from stealing your car.
Happy Racing !
If We Don’t Get Cawt We Ain’t Cheatin’
Old Apr 28, 2014 | 07:36 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
If you have a carb engine ,any thief with enough time can hot wire underhood direct from the batt to the coil and starter
bypassing any " security " you have upstream
Old May 12, 2014 | 11:52 AM
fervernt's Avatar
this is true. Maybe also add a removable steering wheel to the mix?
Old May 12, 2014 | 12:16 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
I had a hidden switch on a car once. It worked fine but I forgot about it a couple of times and couldn't figure out for a while why the car wouldn't start. Now I have a car that no-one would want to steal anyway!
Old May 12, 2014 | 12:57 PM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
i would like to see the theif who attempts this, popping the hood, running a couple wires LOL
Old May 12, 2014 | 01:35 PM
fervernt's Avatar
lmao I've done it myself xD
Old May 12, 2014 | 11:09 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
I was thinking a good place to put a security switch on a manual car is the Clutch safety switch.
Old May 19, 2014 | 10:31 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
There are all kinds of switches with multitudes of different places that you could put them, any of which would work fine. To each his own. IMO there are weak links to any anti-theft solution you choose so just choose whichever fits your budget and needs the best. Using two or three devices/schemes in combination is always the best approach and as always don't park in questionable areas for extended amounts of times.
Old May 20, 2014 | 07:34 AM
Joe Tag's Avatar
Most of our cars have an electric fuel pump. I would disable it before I would the hot lead to the distributor. The break could be made under the carpet at the rear seat. This would take much more time to figure out and be more difficult to bypass.(no hot in reasonable proximity) Starter disable is a good idea too. My 84 SC I sold had a chapman lock, disabled the distributor and locked the hood. I have been debating putting a kill switch in my car, but it's always in the garage. When it's not, I'm driving it. Rarely gets parked anywhere and not for long.
Old May 23, 2014 | 07:12 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Like I said " given enough time "
Have done it plenty of times myself ;10 min max
Old May 23, 2014 | 07:00 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
old school anti theft trick is to replace the coil wire with a piece of same color and size vacumn hose.of course nothing beats a good alarm.
junior419
Apr 7, 2025 11:35 AM
RS Reaper
Oct 17, 2018 07:52 PM
FormulaEngland
Sep 30, 2015 01:50 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
RS Reaper
Sep 27, 2015 07:04 PM
