Charging lugs
Old Apr 30, 2014 | 03:57 PM
mr z28's Avatar
Car: 74 Nova prostreet 87 Iroc Z28
Engine: 427 671 blower 350 Built
Transmission: 700R4 both
Axle/Gears: Dana 60 an a 323 posi.
Charging lugs
Does anyone have any pic. where is a good place to put charging lugs to keep the battery charged up need some help please.
Old May 1, 2014 | 01:46 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Charging lugs
You don't specify what kind of battery you're trying to connect to (post or side terminal). I'm going to assume a stock-type setup.
I use an old model (wall wart) BatteyrMINDer hooked up through the two wire connector that came with the unit.
Autozone sells extended cable bolts where you can attach accessories. The BatteryMINDer is connected directly to the battery.
Old May 1, 2014 | 05:59 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Charging lugs
Do you have a part number for them, or are they just in the HELP! Section?
Old May 1, 2014 | 09:38 AM
mr z28's Avatar
Re: Charging lugs
The lug iam talking about are the one like you put in the back of the car on the outside to car the battery like on race cars. Thanks
Old May 1, 2014 | 04:20 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Re: Charging lugs
Go look on the peg board where they keep the batteries and related items.
Old May 1, 2014 | 04:30 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Re: Charging lugs
I'm heading there tomorrow night for brakes, I'll check it out. Thanks!
Falcon50
Aug 22, 2020 03:26 PM
apie2546
Oct 16, 2016 02:24 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
RS Reaper
Sep 27, 2015 07:04 PM
