VATS Bypassing
Old May 18, 2014 | 02:41 PM
1992PonFirebird's Avatar
Car: 1992 Pontiac Firebird
Engine: 400 sbc
Axle/Gears: 3.73 Limited-Slip
VATS Bypassing
I read how to bypass the system and it said to cut the yellow wire a foot from the connector. I was pulling the wire out to cut it and the wire just pulled out. I didn't cut it or anything but it looks like a very clean cut and now I can't figure out where it goes. Can anyone help? Is the yellow wire the correct wires? There are two wires in the yellow sleeve a white and a green wire. I have looked for the ignition cylinder and it is a orange sleeve with two wires in it. Please if anyone has pictures or can help me through this. I checked the resistance in the key and it is 10ohms so do I need to put a 10ohm resistor on each wire or just one resistor on one wire or 5ohm resistor on each? I know this isn't the safest way but I wanted to run a hidden toggle switch so it is still safe a little. Please all the help would be greatly appreciated.
Old May 18, 2014 | 03:41 PM
Engine: 400 sbc
Re: VATS Bypassing
Okay so I figured out that the yellow wire is for the air bag which I don't have because I have a racing steering wheel. I pulled the plug on the orange wire to test the ohms for the ignition and the key off it has 0ohms and with the key on it has .5 ohms. The key has 10 so does anyone have any recommendations? I tried using my spare key and still nothing
Old May 18, 2014 | 08:21 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: VATS Bypassing
https://www.thirdgen.org/vats_passkey_system
Old May 18, 2014 | 08:25 PM
Engine: 400 sbc
Re: VATS Bypassing
Okay great! Thank you very much.
Old May 19, 2014 | 06:11 PM
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
Re: VATS Bypassing
A simply way to remember is to cut the two wires in the orange sleeve then measure the resistance across the two leads coming FROM the ecm. This is the approx. value the ecm will want to see with the key on +/- 50K. So then just daisy chain however many resistors you need to arrive at the closest value. Radio Shack carries a GM resistor pack assortment for about $5.
junior419
Apr 7, 2025 11:35 AM
$750 L98
Feb 1, 2025 02:25 PM
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
Racerx974
Sep 19, 2015 10:16 AM
