Getting no kind of fire to my plugs.
Old May 20, 2014 | 09:13 AM
xRuee_88's Avatar
Car: 1988 Chevy Camaro RS
Engine: 1994 L05
Axle/Gears: STOCK
I have my 88 camaro and it does not have the original engine in it, there is a 69-79 350 in it and at the point im at, I have replaced the coil, and ICM (ignition control module) and I am still not catching any kind of fire to the plugs whats going on? is it my distributer?????
Old May 21, 2014 | 07:06 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: Getting no kind of fire to my plugs.
Have you checked for power ?
Old May 21, 2014 | 07:29 PM
StealthESW's Avatar
Car: '84 Berlinetta T-Top
Engine: 305 V8 LG4
Axle/Gears: 3.08
Assuming all the other parts, coil, cap and rotor, ICM, and plug wires checkout, it could be a bad pickup coil. In fact, I would not be surprised if it was the pickup coil. It is easily over looked and the next likely culprit. You will have to remove the distributor and take it apart to get to the pickup coil if it needs to be replaced.
I would check the output from the coil and check the pickup coil.
Hope this helps.
RS Reaper
Oct 17, 2018 07:52 PM
Gunner242
Dec 25, 2015 04:49 PM
mrbird
Oct 20, 2015 03:43 AM
hartsmike
Oct 2, 2015 07:11 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
