Another delay wiper problem
Old Jun 8, 2014 | 11:15 AM
dlinger's Avatar
Car: 1984 Z28 HO
We have an 84 Z28 that the wipers worked fine, delay, low and high. The washers were not working so I purchased a new pump. Not knowing I removed the wiper motor cover to replace it and did not put it back on correctly. When I turned the wipers on, it wiped out all the plastic arms and locked up the wiper motor.
I purchased a new motor and installed the old cover and of course delay or washer would not work.
I then purchased a used motor cover and motor off a 87 with delay and installed it. The washers work fine and low and high but no delay wipers.
Hoping it was just a bad cover, I purchased another one (motor and cover) off an 84 Z28 and installed. Same thing, no delay but low and high work.
Any ideas on what else to check?
Darin
Old Jun 9, 2014 | 11:43 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Another delay wiper problem
There is a blue/ish plastic wheel on the cover with a pie cut section.Was the wheel aligned with the pie cut facing up & towards the brake booster?
Also there is a lever on the motor/gear w/ a pin on it.The pin should be on top of the pie cut facing towards the brk booster.If the alignment is off funny things happen with the wipers.
Plus there are two contacts on the left side of the motor.These are not permanently affixed, they slide on/off.Make sure neither is missing.
The cover should be on tight, if a screw is missing or loose.Sometimes the delay wont work, but the slow/fast feature will.
Old Jun 10, 2014 | 08:41 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Originally Posted by dlinger
,.....I then purchased a used motor cover and motor off a 87 with delay and installed it. The washers work fine and low and high but no delay wipers.
IIRC the delay function is controlled by the cover - not the motor. Don't feel too bad,.... your not the first guy to install the cover with the arm in the wrong position causing it to break !
How do you KNOW that the wiper/covers from the 87 or the 84 were Delay parts ??
If I look at a non-delay motor next to a delay motor - how do I KNOW the difference ?
You can't say "because the turn signal had delay on it" because the PO could have made the same error,.. installing non-delay parts or motor by mistake thinking they were delay parts.
Old Jun 10, 2014 | 10:39 AM
dlinger's Avatar
Car: 1984 Z28 HO
Thank you both for your reply's.
I will check the screws for tightness. I did not take either of the cover/motor comb I purchased apart, due to my fear of getting the plastic mechanism messed up again. Only thing I can go by is they both had delay wiper controls (84 I saw, 87 was seller's information). I will open up the one I have on my bench and look inside.
Again thank you for your help!
Old Jun 10, 2014 | 11:04 AM
John in RI's Avatar
I do remember 1 experience with delay vs. non; When I installed a non-delay wiper onto my delay car; When the wipers were active and the wiper speed was moved to a "Delay" position,..... the wiper would stop motion no matter where it was in the sweep.
I'm NOT SURE about the full stop delay activation; might have just raised up an inch or 2 then did nothing,.... returning back to park when turned off.
I honestly don't KNOW how to tell them apart when looking at each side by side and I'm guessing that there must be some way to ID the circuit board inside the cover to verify what type of cover it is ?!?
Please, post your findings !
Old Jun 10, 2014 | 03:36 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Think only the delay option used that funky wheel on the cover.
Old Jul 5, 2015 | 08:42 PM
dlinger's Avatar
Car: 1984 Z28 HO
Thought I would update this. I was finally able to get them working.
As posted the two motors and covers that were suppose to be delay wipers both looked like this.
I know the last one I put on was off an 84 with a delay wiper control turn signal. I should have opened it up before I purchased it.
I watched ebay for quite awhile and picked up
It came new in box with install instructions.
Thanks everybody for the help.
Darin
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
