Fuel Level Sending Unit
Old Jun 10, 2014 | 10:32 AM
82_Camaro's Avatar
Car: 82 Z28
Transmission: Turbo 200C
Axle/Gears: 3.43
I've been doing some searching for a new sending unit and I'm coming up short. does anyone have any ideas where i can get a new one or a working used one? Or if you have any other suggestions on a different problem I may be having? My concern since I've owned the car has been my fuel gauge is pinned past full. with my experience I have diagnosed that to be the Fuel level sending unit.
Any help would be much appreciated. Thank you
Old Jun 10, 2014 | 03:44 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Fuel Level Sending Unit
under the right rear seat bottom is where the fuel sending unit wires come thru the body.when your fuel gauge is pinned past full, usually its the ground wire under the seat that has lost connection.chances are good if you clean it, your fuel gauge will work again.
Old Jun 10, 2014 | 05:52 PM
dlinger's Avatar
Car: 1984 Z28 HO
http://www.justanswer.com/chevy/5nwr...k-cluster.html
When we replaced our tank due to rusting out, our sender unit was rusted also, I think the wire to the float was broken in the tank
Old Jun 12, 2014 | 05:51 PM
82_Camaro's Avatar
Car: 82 Z28
Axle/Gears: 3.43
I'm going to check that out. I really need to see what my fuel level is since the motor swap. thanks
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Irocohio
Aug 12, 2015 08:03 AM
