engine swap now gas pump wont start
Old Jun 12, 2014 | 06:51 PM
camsuper88's Avatar
Car: 88 iroc-z camaro
Engine: 305 tbi
Axle/Gears: idk
im new here and need help with my 88 iroc-z. it has 198,000 miles so i opted for an engine and tranny swap. i put in a new block and a tranny from an 89. my friend helped me time it but now the fuel pump wount prime. the new engine dose not have all the emissions stuff anymore. i have tried replacing a bunch of stuff but it still will not get fuel. please help. any ideas are welcome.
Old Jun 25, 2014 | 05:38 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Not Ready 4 Prime Time
To test the relay and pump simultaneously use a spare piece of wire and jump the orange wire to the green wire with the white stripe.
Did you hear the pump run when you did that?
Happy Racing !
When you see fog or “running” lights on in good weather beware. WLow performance driver ahead.
Old Jun 25, 2014 | 10:31 PM
camsuper88's Avatar
Engine: 305 tbi
Axle/Gears: idk
Re: engine swap now gas pump wont start
i ran a wire from the battery to the fuel pump port on the computer connection under the steering wheel and the pump kicks on. it just wont prime when i turn the key.
Old Jun 30, 2014 | 08:37 AM
NINÅ's Avatar
Transmission: 765R4
With the car OFF, using a voltmeter with long leads so you can see it in the cockpit, probe the green wire with a
White stripe at the pump relay.
Now turn the key to the RUN position.
Did the voltmeter show voltage?
If no, there is a faulty ECM or bad connection going to it.
Happy Racing !
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
Old Jul 6, 2014 | 04:31 PM
camsuper88's Avatar
Engine: 305 tbi
Axle/Gears: idk
so i figured out what is wrong with my car totally by accedent. i bought a new computer for it but put the old one back in and it fired right up. so i guess i just reset it.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
