No power to RH headlight
Old Jun 18, 2014 | 10:03 AM
gta_knight's Avatar
Car: 1987 GTA
Engine: 350 TPI w/ extras !
Hi all,
Im putting the front end back together on my car and the headlights both pop up, but im getting no power to actually light the bulb up on the RH side only. the main beam wire is tan with a white stripe and the high beam is light green, so ive tested each wire at points along the harness incase of a break but ive got as far as under the brake master cylinder area and still nothing.
Is there a fuse for each headlight somewhere other than the fuse box itself ? theres a black ring connector poking out of the harness near the headlight motor plug and thats good a good ground connection.
Old Jun 30, 2014 | 08:24 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Refuse The Fuse
There are no fuses.
It sounds like there’s break in the harness.
First, jump the ground side of the dark headlight to battery negative to make sure it isn’t a bad ground causing the problem.
If it isn’t you will probably have to remove some electrical tape and examine the wiring until you find the bad connection.
Because the left works but not the right, look at the tie-point behind the left headlights.
You can use a small bulb or voltmeter to probe there.
Happy Racing !
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
GTAman
Mar 15, 2019 11:40 AM
sailtexas186548
Aug 24, 2015 10:11 PM
stalkier
Aug 13, 2015 12:59 PM
