Instrument Cluster(Speedo Repair)
I have a 91 TA with the analog gauge set that, my odometer has stopped running. Typical issue with the cluster becoming "gummed" up melted if you will, can some one recommend a repair shop to send to that will not break me? Thank you
Scott
Scott
Re: Instrument Cluster(Speedo Repair)
TheSnake16,
I am having the same issue with my 92' analog odometer. Car has very low miles (20K), all other gauges are working normally, but the odometer just stopped working last weekend. Please let me know what you find out about possible fixes for yours. Thanks a lot!
What I see on all most all of these is the gear has melted, sticky and gummed up. If I could find the gear I would swap it out. Pretty common problem with the lube GM used back then
rs_z28_vert
Sep 30, 2015 09:47 PM
