92 RS headlight questions
Old Jun 20, 2014 | 03:26 PM
Citation X's Avatar
Car: 92 RS
I recently installed some new head lights with the angel eyes led's. The new headlights themselves are just a halogen bulb. After installing the hi beams are on but dim when just the low beams are on and vice versa. Today I noticed the headlights flickering. I shut them off and checked the plugs to make sure one wasn't a bit loose. Started it back up and it seemed fine for a few mins then started flickering again. Any ideas?
Old Jun 20, 2014 | 08:05 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: 92 RS headlight questions
I'm pretty sure this is your problem. If your replacement low beam lights use an H4 bulb, you need to re-pin the connector.
https://www.thirdgen.org/tech/images/connect.gif
Old Jun 20, 2014 | 08:24 PM
Citation X's Avatar
Car: 92 RS
Ahh thank you very much. I think they are an h4 bulb I will check.
GTAman
Mar 15, 2019 11:40 AM
DiabolicalRS
Aug 26, 2015 07:35 AM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
