Please help ! tail light won't turn off and brake lights wont work!
Old Jun 26, 2014 | 12:52 PM
89trying's Avatar
Car: 89 camaro rs
Engine: 5.0
I just changed a fuse that is a 5 and a 15 and a 3 i did this because my rpm gauge and fuel and battery and temp gauge wasn't working but the mph was working so i thought this would help the problem but as soon as i changed out those fuses my rpm gauge flipped all the way to the right when i turned the car on and my fuel gauge went to half and the others were still messed up and my tail lights wouldn't turn off when i'd turn off the car and the car ... i'm not sure what to do ... because i checked the fuses again and the 5 and 3 were still messed up ... i used the tool that lights up ... the one to check the fuses .. i even used the tool to touch the wire from in back of the fuse box but my tool didn't light up so it's like i'm not even getting current through the wires ... i don't now what to do .. i don't know what i did wrong .. is there another fuse box i didn't check ... i don't know what to do please help. thank you. and the wire you see is the way the guy i bought the car from connected the radiator cooling fan
2014 06 25 19.19.37
Old Jun 30, 2014 | 08:34 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Tell The Tail
OK we’ll tackle the taillights won’t turn off first so it won’t drain the battery.
Make sure the lightswitch is in the off position.
Using a small bulb or voltmeter probe the
brown wire at the headlight switch.
Is there power there?
Happy Racing !
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
Frozer!!!
Jan 19, 2024 04:55 PM
Jae992
Aug 27, 2015 09:07 AM
Omega
Aug 10, 2015 12:46 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
BrianI
Aug 9, 2015 11:52 AM
