1986 IROC Z Z28
Old Jun 27, 2014 | 11:10 PM
RedIrocZZ's Avatar
Car: 1986 Camaro IROC-Z
Engine: 350 C.I.
1986 IROC Z Z28
My IROC-Z RPM and battery gauge stop working also my right turning signal stays on when I turn on the lights what could it be?
Old Jun 27, 2014 | 11:35 PM
Joe Tag's Avatar
Re: 1986 IROC Z Z28
The contacts for the cluster often get corroded and don't make a complete circuit. Not a fun job to pull the cluster, speedo cable is a beech. More so to put back than remove. But try removing the cluster and using vinegar or lemon juice on a Qtip to dissolve the corrosion.
Removing cluster (copied from another thread)
1)
Click on picture for bigger view
Remove the 8 screws holding on the plastic dash cover
2)
Remove the 2 10mm nuts
3) Reach your hand behind the dash and squeeze the tab on the speedometer cable to release it.
Steven 86IROC-Z
May 24, 2026 04:52 AM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
StevenB L98/LS1
Aug 22, 2015 09:03 AM
mustangman65_79
Aug 11, 2015 03:17 PM
