Auto To Manual
Old Jul 12, 2014 | 08:52 PM
gregl316's Avatar
Car: 91 RS convertible
Engine: 330 hp vortec 350. TBI
Transmission: 5 Speed
Axle/Gears: 3.73 Moiser 12 bolt/Wilwood disc's
Auto To Manual
I just put a T5 in my 91RS. I am trying to make everything work. I have the netural safty switch working sort of. But with it running the starter engages. Any idea's on what to do and what I did wronge.
In the center consol there is a relay of some sorts that has lots of wires going to it. Any one have a diagram? I did it when I put in a B&M shifter but since forgot what I did.
I just want the
1. Netural safty switch to work
2. Back up lights to work
3. Cruise to work rite
That can't be to hard. I know lots of people have done it with 100% success.
Old Jul 12, 2014 | 08:58 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Auto To Manual
and I'd do it just like they did.
a search of the T56 swap thread should help with the wiring switch from auto to manual.
Old Jul 13, 2014 | 06:37 AM
gregl316's Avatar
Re: Auto To Manual
I read the thread and it is almost the same as mine. I just asked for a little help on my situation.
Old Jul 15, 2014 | 05:37 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Transmission Transition
If what you are trying to say is the starter will not engage in reverse and or neutral but will engage in gear, then the problem is alignment, not electrical.
If the backup lights work, but not in reverse, that’s consistent with alignment.
Therefore if alignment is the problem, the cruise will also be affected.
If the ‘relay’ is yellow it’s for the Airbag.
Happy Racing !
If You’re Passed By Your Own Tire On The Track, It’s Time For A Pit Stop
Old Jul 22, 2014 | 09:55 AM
Rocket-Doc's Avatar
Car: 1990 RS/SS modified
Engine: 355ci, 113 heads, LT4 hotcam
Axle/Gears: 3.73 Eaton posi
Re: Auto To Manual
https://www.thirdgen.org/forums/elec...l-harness.html
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
RyanJB
May 7, 2016 06:23 PM
88rscamar0
Sep 23, 2015 09:08 PM
Magman
Sep 12, 2015 11:55 PM
Isaac McCormick
Sep 12, 2015 10:20 PM
