fan relay
Old Jul 23, 2014 | 05:48 PM
chevyll67's Avatar
fan relay
Hi tryin to fix my hacked fan wires and everytime i put power to the orange relay wires wen the fans cut on the headlights cut on dimly and dnt cut off till i cut car off plz help
Old Jul 24, 2014 | 12:10 AM
Rockguy's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
Re: fan relay
The problem is none of us know what has been hacked up. We also have no idea what the year, make, and model of your car is. Try to put the wiring back to how it was before someone hacked it up.
Old Jul 24, 2014 | 07:29 AM
chevyll67's Avatar
Re: fan relay
Sry its a 87 iroc they cut the power to the relays and tried to wire it to run all the time
Old Jul 24, 2014 | 10:36 AM
Rockguy's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
Re: fan relay
It sounds like it's just more than the fan relay wires that are messed up. The headlights shouldn't be coming on when the fan needs power. Is all of the wiring there to reconnect it the way it was? That would be your best bet. If it didn't work that way, you could then troubleshoot as to why. I assume you have two fans.
Falcon50
Aug 22, 2020 03:26 PM
sheachopper
Jul 31, 2019 11:27 AM
thunder57
Nov 7, 2015 02:28 PM
Fanatic1074
Oct 2, 2015 03:47 PM
