fuel gauge
Old Aug 17, 2014 | 08:50 PM
mr z28's Avatar
Car: 74 Nova prostreet 87 Iroc Z28
Engine: 427 671 blower 350 Built
Transmission: 700R4 both
Axle/Gears: Dana 60 an a 323 posi.
fuel gauge
Hi Guys I have a 87 iroc an in side the car in the back under the carpet where the wirer for the fuel gauge comes out are a pink brown an black I know the black is ground an the others are for what? my gauge is on full an there is a 1/4 of a tank could someone tell me how to fix it . Thanks
Old Aug 17, 2014 | 09:57 PM
seiplentz's Avatar
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
Re: fuel gauge
Sending unit in the tank is probably bad. You can use an ohm meter to read one of the wires to ground and you should get from 0 to 90 ohms for a good sending unit. 0 is empty and 90 is full I think.
Old Aug 17, 2014 | 10:40 PM
Joe Tag's Avatar
Re: fuel gauge
When the gauge reads full like that, usually the ground is bad. Try cleaning rust or dirt off under the eye in the ground wire and making sure the screw is tight. If that doesn't work,the pink wire is the signal from the sender. Test resistance from the pink wire to ground. 0 is empty and 90 is full. You will be looking for something in the 15-20 ohm range for 1/4 tank.
Old Aug 18, 2014 | 03:37 PM
mr z28's Avatar
Re: fuel gauge
I have checked the ground an it is good the pink an ground together an the gauge goes to empty when you take the ground off the gauge it pegs full. This is under the driver side trim pink black an tan what is the tan ? from under the car their is a purple orange an black off the tank this is a carbureted car. Thanks.
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
justin57
Aug 20, 2015 07:05 PM
Jk_Under
Aug 17, 2015 03:08 PM
R3500
Aug 17, 2015 12:16 PM
