convert side post battery terminals to top post battery terminals
Old Aug 22, 2014 | 02:02 AM
Steveh4263's Avatar
Car: 1987 Pontiac Trans AM GTA
Engine: 5.7 LTR
Transmission: Automatic
I have a 87 GTA and I want to convert the side post terminals to top post terminals. I have the side post bolts that have the accessory nut to hook up a car alarm siren to the post side terminal. Anyway the bolts got cross threaded in the battery. So I think it screwed up the the bolt holes and the bolts. I have to disconnect the battery when the car sits to long, as the car alarm will drain the battery. Also the car is put in storage in the winter time so the side post bolts have to come out as well as the battery. I'm just po'ed about the whole thing.
Old Aug 22, 2014 | 05:20 AM
Restrorob's Avatar
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
Re: convert side post battery terminals to top post battery terminals
I had the same problem with my show truck (avatar), I went to a duel post battery and use the top positive post for accessories. Then I added one of these to the negative cable; http://www.summitracing.com/parts/lng-45748/overview/
No more issues......
Old Aug 24, 2014 | 12:20 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
A mechanic once told me that some battery's converted to top post from side posts can be a lot closer to the hoods location when closed .
Also if you need a place to draw constant power from there is a "power terminal/ junction block " mounted close to the battery on the frame.
It has a lead coming off of the positive battery cable going to it and is where fans ,etc draw there power from .
It is very hot at all times so disconnect the battery ,both positive and negative before touching it.
Looks like this on my car =
1992 Trans Am
May 10, 2023 07:19 PM
Jae992
Aug 27, 2015 09:07 AM
Dan Hubbard
Aug 12, 2015 09:05 PM
