connector identification help
Old Sep 7, 2014 | 05:34 PM
camarozz383's Avatar
Car: 1989 camaro rs
Engine: ls 5.3 carb
Transmission: t56 six speed
Axle/Gears: 3:73
can you tell me where these go? thanks
Old Sep 7, 2014 | 05:35 PM
Car: 1989 camaro rs
Engine: ls 5.3 carb
Axle/Gears: 3:73
Re: connector identification help
and these!
Old Sep 7, 2014 | 08:36 PM
TBRays98's Avatar
Car: 1989 Formula
Axle/Gears: 3.45 1LE Disc LSD
First one on first post is for the knock sensor
Old Sep 8, 2014 | 03:22 AM
Car: 1989 camaro rs
Engine: ls 5.3 carb
Axle/Gears: 3:73
ok thanks tbrays98, and I know what the tan wire is for, now for the second post?
Old Sep 8, 2014 | 06:42 AM
Last one (yellow & black) is coolant temp sensor
Old Sep 9, 2014 | 11:08 AM
Pocket's Avatar
Car: 91 Trans Am
1) Depends on wire color, dk blu Knock. Dk Grn, thermal switch for fan relay
2) Tan/wht can be a number of things, you need to find a pin location. If its 18ga, then its either brake warning switch or fan relay fuse. 12ga, fuel pump. For your 89, Id wager its the brake warning
3) Left washer tank motor Right back-up lights switch connector
4) Wiper motor lower connector
5) CTS
Old Sep 9, 2014 | 06:16 PM
Car: 1989 camaro rs
Engine: ls 5.3 carb
Axle/Gears: 3:73
the tan and white is fuel, and what Is cts? dumb *** at wiring :[ thanks Pocket that helps me so much, appreciate all you guys helping me.
Old Sep 10, 2014 | 08:04 AM
Pocket's Avatar
Car: 91 Trans Am
Old Sep 29, 2014 | 06:47 PM
Car: 1989 camaro rs
Engine: ls 5.3 carb
Axle/Gears: 3:73
Hey pocket can you help with these?
Attached Thumbnails connector identification help-img_20140929_195449.jpg   connector identification help-img_20140929_195534.jpg
Old Sep 30, 2014 | 09:25 AM
Pocket's Avatar
Car: 91 Trans Am
Distributor
MAP/BARO sensor depending on tbi or carb
Old Sep 30, 2014 | 10:45 AM
Car: 1989 camaro rs
Engine: ls 5.3 carb
Axle/Gears: 3:73
thanks again pocket, now i have another question, I have dual fans in my car, and I need to run new relays for them, can you tell me what wiring I dont need from the factory harness?
Old Sep 30, 2014 | 11:11 AM
Pocket's Avatar
Car: 91 Trans Am
If this is for a LSx swap in your info, then basically all the old wiring goes away. Practically every connector posted on this page is trash
Old Sep 30, 2014 | 11:45 AM
Car: 1989 camaro rs
Engine: ls 5.3 carb
Axle/Gears: 3:73
ok thats awesome! thanks again
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
