1985 Berlinetta Wiring Help!!
Old Sep 30, 2014 | 10:15 AM
CamaroOKc's Avatar
I've searched all over this site, also over the net, to find a very specific wiring diagram for my 1985 Camaro. I'm doing an engine swap from the LB8 to a good ole 350 TPI. The dash connectors diagram worked marvelously, but I'm still having trouble locating the correct diagram for my C207 (white) connector. All of the other diagrams do not follow the same pattern as mines, as it does not have a wire in the A-pin. Any help will be greatly appreciated, and if you need more info about it to help us both out, let me know.
Old Sep 30, 2014 | 12:09 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: 1985 Berlinetta Wiring Help!!
I had to scan every schematic in the shop manuals to come up with the C207 info for the early cars...... I am not sure that the 85 info is EXACTLY accurate - but I'm sure that it's REAL close !!
Good Luck with your swap !
http://berlinetta.info/C207.htm
Edit: Be sure to notice that the 85 C207 was VERY dependent on the type of engine in the car !!
armybyrd
Dec 5, 2015 09:22 AM
Reddeath210
Oct 6, 2015 08:20 AM
Thornburg
Aug 26, 2015 07:22 PM
bbernardo94
Aug 19, 2015 05:25 AM
Fronzizzle
Aug 17, 2015 02:52 PM
