Whats this behind the radio?
Old Sep 29, 2014 | 05:07 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
hey guys, I'm trying to figure out why my dash lights dont work on my 86 trans am. I replaced the remote dimmer switch and nothing changed, I narrowed it down to the dimmer wheel or the kenwood radio the P.O installed. while looking behind the radio for the grey illumination wire (couldnt find it) I noticed this fuse holder. whats it for and what size fuse goes in it? could this possibly cause me having no dash lights?
Old Sep 29, 2014 | 05:57 PM
Joe Tag's Avatar
Re: Whats this behind the radio?
That's not a fuse holder. Orange is the constant hot for the radio, brown is the radio display dimmer, controlled by the dimmer wheel. It would be on the tail fuse, 20 amp.
Old Sep 29, 2014 | 06:09 PM
TylerSteez's Avatar
Engine: 383 stroker
What would I need to do to it to get my gauge lights working? No fuses are blown
Old Sep 29, 2014 | 06:40 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
A quick glance through the '86 Body Wiring Diagram on Austin 3rd gen, the only things that have an orange and black wire are the cigarette lighter and the glove box light.
http://austinthirdgen.org/mkportal/m...ody_wiring.gif
Old Sep 29, 2014 | 06:50 PM
Joe Tag's Avatar
Here's the actual stereo wiring on an 86.
But that's beside the point right now. I'd suspect the dimmer on the headlight switch. Check the brown wire for power with the lights on and the dimmer turned all the way up. then start checking grounds if it has power.
Old Sep 29, 2014 | 07:33 PM
TBRays98's Avatar
Car: 1989 Formula
Axle/Gears: 3.45 1LE Disc LSD
Its a radio dimmer hookup.
Old Sep 29, 2014 | 07:38 PM
TylerSteez's Avatar
Engine: 383 stroker
when you say dimmer on the headlight switch are you referring to the wheel?
Old Sep 29, 2014 | 07:43 PM
Joe Tag's Avatar
Yes, separate from the headlight switch on a firebird but is connected to it.
Old Sep 30, 2014 | 11:18 PM
TylerSteez's Avatar
Engine: 383 stroker
So it turns out when I replaced the remote dimmer switch a couple days ago I did fix my dash lights, stupid me didn't realize that the dash lights only turn on when the headlights are on, whenever I did have my headlights on I had the wheel rolled all the way down.. Thanks everyone for the advice
Old Sep 30, 2014 | 11:25 PM
Joe Tag's Avatar
Doh! Always the simple things that trip you up. Glad you figured it out.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RS Reaper
Oct 17, 2018 07:52 PM
Fireslash
Apr 11, 2016 06:43 PM
Gunner242
Dec 25, 2015 04:49 PM
John in RI
Car Audio
Sep 10, 2015 11:24 PM
