car wont crank?
Old Sep 13, 2014 | 07:43 PM
straightbuchana's Avatar
Car: 82 Pontiac Trans Am
Engine: 350 Vortec, sprayed
Axle/Gears: Spooled Strange 12 bolt, 3.73 gears
car wont crank?
I have an 82 trans am with a 305 motor. I just put another 600 edelbrock on yesterday, it had a 600 holley. After having problems starting the car with the new carb, I ended up having to replace the fuel pump. But now, even after tuning the carb, I'm having other issues. Sometimes, when I turn the key for the ignition, nothing happens. My check engine light comes on as usual, but the engine does nothing. I replaced the starter not long ago and its still good. Other times, my car cranks fine. Could this be a wiring issue? If so, any ideas on how to solve it?
Old Sep 22, 2014 | 06:02 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: car wont crank?
possibly a bad park/neutral switch. try messing with the shifter when it doesn't crank.
Reborn756
Sep 4, 2015 03:42 AM
TheExaminer
Aug 26, 2015 04:59 PM
Thirim
Aug 13, 2015 03:09 PM
mizz0313
Aug 12, 2015 06:45 AM
gwade12
Aug 8, 2015 08:17 AM
