TBI injectors not firing on startup
Old Sep 23, 2014 | 07:41 PM
smartone4765's Avatar
Car: '92 RS
Engine: Vortec 350 engine code L-31R
Transmission: 700-R4
Axle/Gears: stock rear (for now)
so my car seems to have a gremlin. All seems well, the car will crank, the fuel pump clicks on, the injectors have pressure (I have an aftermarket regulator with a gauge), the injectors work (I have applied power to them directly) but they do not fire when cranking. I was able to get the car to run by cranking while spraying brake cleaner into the intake. Once the engine fired and ran for a few seconds, the injectors started working again. unfortunately this seems to have been a one trick pony as when I tried the same cheat again I was unable to get the injectors to kick on.
Thoughts?
Its gotta be a wiring issue or a problem with the ECU right? there arent any relays for the TBI injectors are there?
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
