86 camaro carb swap which relays?
Old Oct 12, 2014 | 08:38 PM
camaro8484's Avatar
have a 86 camaro that someone swapped a 350 in.. carbed, one MAF and fuel pump realy is gone, do i need the other MAF one and the ESC one ? any info would be great, trying to get all the old wiring mess gone to have a clean engine bay not a million connectors that i don't need.
Old Oct 12, 2014 | 09:08 PM
Eric-86sc's Avatar
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
Re: 86 camaro carb swap which relays?
Was it a factory v8 or 2.8 car? If it's a v8 car and there is a harness on the ps of your engine bay, unplug it from the computer and remove every lead the wires end at. I have the same car with the same swap (86 camaro 350) and the only relay left on my firewall is the electric fan relay. A 2.8 should be the same principle but I am not 100% certain if a 2.8 computer and gauge harness are separate.
Old Oct 13, 2014 | 06:06 AM
camaro8484's Avatar
Yeah it was a factory v8 car with all of the harness coming from passenger side. I wanna get all these wires cleaned up/hid. I thought I wouldn't of needed the ESC or MAF relay anymore just wanted to make sure be4 I unplugged it. Kid fried the motor they swapped in it. Which is ashame but oh well. So while I have the motor out figured I might as well clean up the bay a little bit. So when you say in plug everything, there a little connector right under my maf an where the fuel pump would be. Pretty sure I don't need them anymore but I'm not positive. Thanks!
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
Caspar
Jun 19, 2016 11:19 PM
