wiring harness ?
Old Oct 15, 2014 | 09:47 AM
Poseidon's Avatar
Car: 1991 Firebird
Engine: 305 tbi Stock
Axle/Gears: 2.73 posi
wiring harness ?
I totaled my 87 formula I bought a 86 v6 roller that was converted to v8 can I just unplug the harness at the passenger fender and plug my v8 harness in I run the qcc electronic quadrajet I know swap the ecm passenger kick panel are there any difficulties I may run into any help would be great
Old Oct 16, 2014 | 10:53 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: wiring harness ?
Assuming that both cars are Automatics and that both harnesses are Firebird;
Those 2 years were pretty similar; I would expect there to be a minor change or 2 - but for the most part it's a pretty good "fit".
The 1 thing I can think of is that the 86 dash harness might not have a 12 volt "switched" power wire for the carb Electric choke wire.
Best advise is to print out the C100 & C207 diagrams from each year and start comparing each and every PIN to see what is and not a direct wire-to-wire fit.
C100:
http://berlinetta.info/C100.htm
C207 (&221) :
http://berlinetta.info/C207.htm
Old Oct 20, 2014 | 09:18 PM
Ferro's Avatar
Car: 91 RS
Engine: 5.0 TBI LO3
Transmission: Built 700R4
Axle/Gears: LSD
John in RI whats up.. Looks like you know a thing or two about harnesses. I just re-installed my tranny. 91 Rs. There are two grounds coming out of the wire harness rite where it sits on the bellhousing. Do I attach them to one of the bellhousing bolts or do they go elswhere. Of course it does not start rite up. I may have incorrectly wired my starter but I'll double check that after I get this squared away. Any help is appreciated.
Old Oct 20, 2014 | 09:38 PM
John in RI's Avatar
The factory put ground connections on the back of EACH head.
You can bolt the heavy ground wires about anywhere on the motor,... the holes in the back of the heads is preferred over the bell-housing because it's easier to reach and so that removing the tranny ( for whatever reason ) will not effect the electrical system.
Back of the heads gets my vote !!
Old Oct 20, 2014 | 09:49 PM
Ferro's Avatar
Car: 91 RS
Engine: 5.0 TBI LO3
Axle/Gears: LSD
Thanks or the quick response bro. However, it doesn't seem to reach properly to the back of the head. I'll give it another shot though. I'm working on it now. Dude I bought it from said it was a Z28. It's an RS with a Z hood and Wing. Not happy about that at all.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
armybyrd
Dec 5, 2015 09:22 AM
stalkier
Aug 21, 2015 01:54 AM
