Digital instrument cluster
Car: 89 GTA
Engine: 5.7 TPI
Hey I see a Digital instrument cluster was offered in a 88-87 GTA trans am... My question is will it work with a 89 GTA? Also is there any re wiring I need to do?
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Digital instrument cluster
The ENTIRE car would need to be re-wired with the proper harnesses for the conversion to work properly. Engine harness, Dash Harness, Body Harness, Tail light harness,....ect.
Car: 1989 Trans am GTA
Transmission: t56 6 speed
Axle/Gears: 3.45
I did the swap into my 89 GTA. If you're interested in doing it, look at my thread to see what's involved.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
On top of all this, the actual dash itself is specific to digital dash, you can't retrofit to an analog. It's quite an undertaking, even if you have every piece off of a complete donor car right beside you.
Car: 89 GTA
Engine: 5.7 TPI
You mean the bezel right? Yeah, I figured by looking at it the dash was different. But I swapped a digital instrument cluster into my Ford Taurus SHO and that wasn't too bad. Also the one that did it before could you post a link to your post?
